Offer: Burnham MPO IQ84
Newtothis
Member Posts: 12
Manufacture date from 2010. There is a small amount of paint coming off the burner tube.
Matching 2-250 gallon tank that appears to be installed around the same time as the boiler. Cursory inspection shows no corrosion.
Located in Northern Virginia.
Where in N. Va?
Can you post a pic of it?Bob Boan
I'm in Fairfax VA. This is a standard out of the crate boiler. Here is a link to pictures and all of the tec documents you could need.
http://ecomfort.com/mpo-iq-60-gph-hot-water-boiler-oil-87-afue-chimney-vented-92520.html0
- 123 Chimneys & Flues
