boiler system winterization
driger
Member Posts: 1
i have a summer home water heat, basically its a sentinal slant fin boiler with baseboards throughout the house. i never use the boiler and because i snowbird to arizona during the winter months. so i'd like to winterize the system and forget about it. what it be better to have the system filled full of heating system antifreeze or carefully empty the system by blowing it out will air? i understand the risks of blowing the lines out, but there are openings at the low points of the lines, so the pipes can be thoroughly blow out.
thanks in advance.
thanks in advance.
Don't
blow it out . I cannot even count how many times I have had to change burst piping and components that were blown down . Things you cannot see like trapped water , all the low loops below the floor between baseboards always biting people who thought they did the right thing in the **** . Have the system charged with the appropriate amount of antifreeze % and have a good winter in AZ .
By that token , same with your plumbing , have a plumber fill your entire system with RV antifreeze (100%) from a barrel with a pump . run all faucets until solution comes out of all of them . Don't forget the traps . When you come back in the spring just turn on the water and all the faucets until all color and taste is gone .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330
- 167 Indoor-Air Quality
