Directing heat down from Overhead steam baseboard radiator?
mmm613
Member Posts: 1
Hi,
Making a bedroom from what used to be a basement garage: has an overhead steam baseboard radiator in a top corner. My idea: to put an intake fan right behind that radiator (there is an area behind the radiator) and direct the hot air through in-wall rectangular duct 3 -1/4" by 10" (?) down and to the floor . -Of course to hook up the fan with a thermostatic switch attached to the radiator.
The problem: Cannot find an vent (exhaust) wall fan quiet enough for the bedroom and designed for hot air ( a regular bathroom fan is not designed for steam radiator temps).
Any suggestions about a fan or any alternative heating solutions would be greatly appreciated. (And yes, of course I am on a tight budget - otherwise I wouldn't convert garage to bedroom :-)(
Thnaks
Thnaks
Wanting:
You can have ANYTHING you want.
Just not EVERYTHING you want.
Decision time about what is important and how much you are willing to pay for it.0 -
Steam
Radiant energy is like the Wonkavator...
"An elevator can only go up and down, but a Wonkavator goes sideways and slantways and longways and backways and frontways and squareways and any other ways that you can think of..."
A fan won't make heat go anywhere, though. It can make air go up or down, but heat goes everywhere on its own. Are you having trouble heating the room?0
