Bryant 244-7 Series A Gas Steam Boiler
MikeMens
Member Posts: 30
I have a Bryant 244-7 Series A gas Boiler (yes its very old)
I have 1 or 2 bolier segments that are leaking and I would like to replace them.
Any suggestions as to aftermarket or discontinued/rare parts distributors where I might find them? I am trying to keep this thing going for 3-5 more years then replace. (kids in college)
I also want to replace the gas valves and pressure controls (valve sticking & not responding to thermostat
Any suggestions would be appreciated
Mike
518-810-7222
Mike
518-810-7222
Needle in a haystack
Finding old discontinued boiler sections will be very difficult. Anyone who has been keeping old sections has been doing so because he thinks they are VERY Valuable!. The amount of work to replace them , if you could find them would be more than installing a preassembled boiler.
Why not add up the EDR of your radiators and then we can help you find an appropriately sized boiler from pex supply or some such place. Do not go off the plate from the old one, but measure the rads.--NBC0 -
+1
Apart from the cost, in time and parts--if you can even find them--of restoring an antique, have you considered the greater efficiency available in the newer boilers?Just another DIYer | King of Prussia, PA
Thanks for the replies.
I hear You and agree its just a $ issue. Kids in college etc
just looking for alternatives that dont require me to pull my kid from college
A couple of people have said adding sealer to the boiler to seal the leaks might buy me some time
Any comments on that option to get me thru the next couple of years?0 -
Nothing can seal boiler leaks.
Boiler additives that claim to seal or prevent leaks just cause foaming and wet steam. I think you need to explore financing options.Just another DIYer | King of Prussia, PA
Won't work long term
Boiler sealers might work for a week and maybe a month - if your lucky. They will NEVER work for years.
I suggest you look into financing now while you have some control over the situation. If that boiler has to be be replaced on a cold January night you will pay a lot more than you would now when installers are not going crazy.
3PSI gauge0
