Buderus Indirect Hot Water tank
jmy
Member Posts: 1
So I just moved into a new home and it has a Buderus GB142 gas condensing boiler. For some reason, probably cost, the old owner installed an electric hot water heater about 2 feet away from the gas line coming into the house. I am investigating my options for switching my hot water heating over to gas and I believe I have two options. I could get a stand-alone gas hot water heater for $400-500 and have that hooked up, or I could go with a Buderus indirect hot water tank, probably a SU54. I have not received the quote yet, but I'm assuming based on what I have seen online that the Buderus is going to be pricey. The question is...is it worth the extra cost? I will be in this home for at least 7 years, possibly more.
Thanks.
Thanks.
Anode rods
suck . I like Buderus' stuff and have used it many times . When it comes to indirects though HTP has the best in the business . SuperStor indirects have a no BS lifetime warranty , are stainless steel , no anode rods to change . You should even be able to use the DHW sensor from Buderus so it communicates nice .
http://www.htproducts.com/superstor-ultra-waterheater.htmlYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
pricey
You run your electric water heater and you will see pricey.Put an indirect on and bite the bullet.7yrs is a long time.Heating season is coming so get on top of it.A cheaper option might be a turbomax reverse indirect.I hear it works nice and might be cheaper than a indirect.Do your homework and I am sure you will get great advice here.Good luck.0
- 123 Chimneys & Flues
