Pressure assist toilets
PA Toilets:
They're great when they are new and work well.
After that, it's all downhill.0 -
Ive had a Gerber in my home for 10 years
works fine. I have quite a few Gerbers out there and have no trouble. I installed a back outlet Eljer about 7 years ago at a local Italian restaurant and have had no trouble with that either and it is much quieter than the Gerber.0 -
Pres. Assist Vs. gravity flush:
The new toilets like the Kohler class 5 toilets flush as well as the old flush ell toilets and outperform the power flush toilets with a fraction of the water. You won't be buying the proper flush valve gasket at HD or Lowes. They take a specific flapper.
That Kohler TV Commercial where the guy sees the hot lady plumber going on a service call and he starts throwing stuff down hos toilet to plug it up and get her to come over and fix it? But it won't plug up? Its MY experience that it is true. You can't plug them up. Well, you can plug up anything. But I replaced a lot of Wellworth's with Cimmeron's and never once had a problem. Early Power Flush units were different manufacturers. As far as my experience goes, they all use Sloan Power Flush units. Some old Kohler units have to have the entire toilet replaced because you can not get a replacement unit. Sloan became the standard for flush mate units0 -
Cimmeron has a good flush but
a lousy water spot. whether its sh#t stains on the inside of the bowl or on a brush sitting aside of the closet..that is gross. Pressure assist have full size water spots and stay much cleaner.0 -
Improvements:
That well may be.
Manufacturers are constantly improving their fixtures.
My 2000/2001 new home in Massachusetts had Wellworth's. One I used was so bad that I had a plunger AND a toilet auger in a closet beside the toilet for almost every use. In 2007, I replaced a Briggs or some other POS competitive brand in my Florida Condo with another Wellworth. It has never plugged up. Same toilet, different internal design.
What isn't stated in the instructions is that there really is a 2 force flush on Cimmeron's, Wellworths and any other low flush toilets. A #1 flush is that you just hit the lever and a small amount of water leaves the tank. For a #2 style more aggressive flush, you hold the handle down while it is flushing. For those special delivery packages to the sanitary sewer system.0 -
The newest generation of Wellworth
are fantastic IMO. 1.28 GPF, under $150 in white, nice spot, and will flush pretty much anything -- be careful with small pets.0
- 167 Indoor-Air Quality
