Emerson swan
Snowmelt
Snowmelt Member Posts: 1,457
Did I hear right,did emerson swan drop ao smith.
It's not like I'm against ao smith but they did me wrong.
They ask me if I wanted to be one of there service contractors I done it for about two years, they send a letter and drop me. Every unit I went out to fix I did or I replaced. I even did a few where the customer gave up and I was last resort.
I have the main guys number and name on my white board from ao smith, he never returned my calls, with that being said, aosmith top dogs are full of themselves I kinda give up on them as a family. To me a water heater is a water heater all it does it heat water.
Oops I was getting carried away, the original question is did emerson swan drop a. o smith?
  • Rich_49
    Rich_49 Member Posts: 2,785
    Emerson Swan
    They did in fact dump AO Smith recently . They also became the rep for HTP and HTP got rid of Gooding as their rep .  Sounds like both companies did a lot of thinking about where the future will bring them .
    732-751-1560
    Rich McGrath 732-581-3833
  • icesailor
    icesailor Member Posts: 7,260
    Water Heaters.
    Because of the new 2015 water heater Reg's, HTP is on the cutting edge of high efficiency water heaters. Emerson-Swan isn't going to be found short for water heaters.
    http://www.htproducts.com/phoenixldwaterheater.html
    hot_rod Member Posts: 26,583
    Doesn't AO Smith
    own Lochinvar? I suspect you will see some really cutting edge tanks and boilers from them also. You already do, actually.
  • icesailor
    Lochinvar:
    Who Reps Lochinvar? I'll bet that whomever Reps Lochinvar will be the new distributor for AO Smith.
  • icesailor
    AO Smith Rep.
    Maybe FIA.
    They rep Lochinvar.
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    I think AO Smith owns the world, don't they?
    Or at least it seems like they do.
    ME
