Pool heating
Snowmelt
Member Posts: 1,439
When doing a pool heater with a HE unit & a flat plate hex what kind of pump/ equipment do you use to bring the pool water to the hex?
Pool
You normally see them piped in series with the filter. They just use the pool recirc pump to move the water.
A flat plate HEX will have a fairly high head loss and is prone to gumming up.
You might look at something like a Triangle Tube Maxi-flo."If you can't explain it simply, you don't understand it well enough"
Albert Einstein1 -
What about
These companies that advertise flate plate heat exchanger for pools, or am I better off getting what you said, something in a tube type product.0 -
Caution...
If the pool chlorination systems uses salt, your regular flat plate heat exchanger WILL turn into Swiss cheese in a year or less. Chloride stress cracking. Use a material that is compatible with sodium if it is present.
ME0 -
Poor
I in the poor section of nj, so that would chlorine pool not salt.0 -
Maxi-Flo
As Carl suggested above http://www.triangletube.com/documents/12/MF%20Literature%20S.S.%20&%20Titanium%202013.pdf0 -
Salt:
You mean like Sodium Hypochorite?
(bleach)0 -
surface area
is what heat transfer is all about. Look at the flat plate pool HX also, you get a lot of heat exchange surface in a small HX. They can be built and sized for close approach and low pressure drop.
Need to know what temperature you have on the A side, those tube and shell need pretty good delta T with small square footage surface area, to give you high output.Bob "hot rod" Rohr
Heat exchangers
Brazed plate HE do not stand up for pool use. We have for over 10 years only used titanium tube and shell HE like this:
http://www.aicheatexchangers.com/tw-line_titanium_heat_exchangers.html0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
