Pool heating
Snowmelt
Snowmelt Member Posts: 1,457
When doing a pool heater with a HE unit & a flat plate hex what kind of pump/ equipment do you use to bring the pool water to the hex?
  • Zman
    Zman Member Posts: 7,611
    Pool
    You normally see them piped in series with the filter. They just use the pool recirc pump to move the water.
    A flat plate HEX will have a fairly high head loss and is prone to gumming up.
    You might look at something like a Triangle Tube Maxi-flo.
    Albert Einstein
    kcopp
  • Snowmelt
    What about
    These companies that advertise flate plate heat exchanger for pools, or am I better off getting what you said, something in a tube type product.
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    Caution...
    If the pool chlorination systems uses salt, your regular flat plate heat exchanger WILL turn into Swiss cheese in a year or less. Chloride stress cracking. Use a material that is compatible with sodium if it is present.
    ME
  • Snowmelt
    Poor
    I in the poor section of nj, so that would chlorine pool not salt.
  • SWEI
    SWEI Member Posts: 7,348
    edited July 2014
  • icesailor
    icesailor Member Posts: 7,260
    Salt:
    You mean like Sodium Hypochorite?
    (bleach)
    hot_rod Member Posts: 26,575
    surface area
    is what heat transfer is all about. Look at the flat plate pool HX also, you get a lot of heat exchange surface in a small HX. They can be built and sized for close approach and low pressure drop.
    Need to know what temperature you have on the A side, those tube and shell need pretty good delta T with small square footage surface area, to give you high output.
  • Henry
    Henry Member Posts: 998
    Heat exchangers
    Brazed plate HE do not stand up for pool use. We have for over 10 years only used titanium tube and shell HE like this:
    http://www.aicheatexchangers.com/tw-line_titanium_heat_exchangers.html
