thread sealant
PDB2
PDB2 Member Posts: 29
In hydronic near boiler piping, is there a preferred type/brand to use
when mating copper to black iron? Or for that matter, a certain type for
all hydronic connections?
  • Snowmelt
    Snowmelt Member Posts: 1,457
    What I use
    Pro dope
  • jumper
    jumper Member Posts: 2,511
    technique can matter too
    especially with cheater thread
  • lza
    lza Member Posts: 40
    pipe dope
    PDB2
    Anything you use will be fine.  I personally use Hercules umm...Megaloc.  I like the consistency.  But pretty much anything will work (and my personal preference for application is a thin layer of dope, then a three wraps of teflon tape, then another thin layer of dope).  The one thing I would advise you on is your choice of fittings.  If you use dielectrics, stay away from dielectric unions as they tend to leak.  If you use a dielectric nipple, I personally always use a brass coupling and then a copper male adapter.  Copper female adapters tend to leak at the threaded joint.
  • lza
    cheater thread?
    jumper,
    What is cheater thread?
    hot_rod Member Posts: 27,046
    I really like
    this 3- Wrap tape from Mill Rose. You really do not need to add any dope with it. Great for rough threads, and comes off the roll better, to the very end.
  • bob_46
    bob_46 Member Posts: 813
    Cast Iron
    The use of teflon tape or paste is not recommended for connections on cast iron baseboard or cast iron headers on coils . It is too easy to over tighten and crack the casting .
  • RobG
    RobG Member Posts: 1,844
    edited August 2014
    If
    If done correctly there is no problem with mating copper to CI baseboard with Teflon or paste, as long as there is room for linear expansion. At least I've never had a problem.
    And if you don't use Teflon or paste how are you going to seal the joint?
    Rob
