Silicone steam pipe through floor?
ChrisJ
Member Posts: 16,708
I have quite a few radiator's who's pipes come up from a crawl space. I've been pondering for a few years if there is anyway I could seal the gap around the pipe.
Has anyone ever used 100% clear silicone for this? I don't see why it would have a problem, certainly not from the heat and I doubt the short amount of pipe connected between the floor and radiator expands much.
I welcome any and all thoughts as always.
RTV
I would use clear RTV, it's good up to 400 degrees. If you want to use regular silicone caulk just look at the label for its temp rating.
Rob0 -
Seal Around Steam Pipes
Silicone may break down quickly around the steam pipes unless it is rated for high temperature (450*F or greater sustained temp. 500*F+ intermittent).
Even then, I suspect it will turn brown and break down after a few years.All Steamed Up, Inc.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc0 -
temp rating
RTV-108, a clear RTV we use at work has a continuous operating temp of 400F.
Gordo, I'm not talking about caulk for around tubs and sinks, maybe I should've said RTV instead of silicone.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Sealing
If you have escutcheons around the pipes you can use any type of RTV. You could always do one rad and use rock wool around the others as a temporary air seal, see how it holds up and decide from there. Or just use rock wool and escutcheons period. That way if you ever need to disconnect anything you will not have to clean up silicone caulk.
Rob0 -
RTV:
High Temp. RTV is used regularly on automobile engines. They run really hot. Hotter than your average residential low pressure steam system.0 -
RTV
That was my point. If escutcheons are used, high temp (orange or black) can be used. The clear only goes up to 400 degrees (which would probably be fine). If it were me, I would just pack it with rock wool.
Rob0 -
Rock whool?
Is rockwhool what is commonly called rotten cotton? If so, no way.
I hate that stuff, we stuffed it around my B-vent's firestops after it was installed to make sure it was all sealed good.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Rockwool
What's wrong with rock wool? I've never had a problem with it. If you're against rock wool you can use fiberglass, it's good up to 1000 degrees. Rock wool is 2200 degrees and is much more user friendly in my opinion.
Rob0 -
Itchy
Itchy, nasty stuff.
Fiberglass isn't much better. I hated every second of insulating my piping, but I did it because I had to.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
- 109 Chimneys & Flues
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
