Second guessing
AFOCT
Member Posts: 5
Looked at a radiant slab install for a customer last week. The customer had radiant installed in another building using a different contractor. ( I spent two days redoing that so it was done properly) I had my wholesaler do a heat loss for the new building slab and it just seems off. Might be I have not done a floor in a long time.
40x40 building with a first floor that is 2x6 construction. The slab is basically the basement with the foundation being half above grade and half below. There are two 12x13 roll up doors and a steel entry door. The 8' foundation walls that are below grade are not insulated. 4' slab, 13'6" height to heated first floor ceiling.
Wholesaler came up with 12 loops of 1/2" tubing @ 200' loop lengths.
Designed for 115 water temp at 0 degree design temp.
Maybe I am just off but it seems like a lot of tubing?
Questions
Are you saying you are heating a 1600 sq foot space with tubing at 9" centers or are there 2 floors?
What kind of underslab insulation?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Answers
The building is basically a one floor house. I am just putting the tubing in the floor of the basement. Unfortunately he purchased enough "insulation to do this floor from the previous contractor. It is insultarp. ( Don't get me started on this stuff) I did talk him into 2" perimeter insulation.0 -
Output
Siggy's software puts your output at about 62K BTU or 39BTU/ft. at the 115 design temp.
That seems a little high but considering the insutarp (I agree it is crap) and the under insulated walls I think I would run with it unless you do a heat loss calc that tells you different.
Too much radiation is never a bad thing, particularly if you are running a condensing boiler."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Not quite clear
Are you planning to heat the basement and let the first floor (which sounds like it could be 4 feet above ground level) live with the leftovers?0 -
Yeah the second floor will be heated off a second zone. My heat loss came up with 63k. I think I just haven't done a radiant install in awhile so I must just be overthinking it. The boiler is gonna be condenser.
Thanks for the input fellas!!!0 -
12 @ 200
Is 12" oc layout . 1,600 ft building , 2400 feet of tube . Besides the lack of quality insulation . Sounds as if the average depth below grade is 4' , any chance the guy will excavate tat and install 2 - 4" of EPS or XPS up against that wall ? That would be a huge help .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
12"?
Rich,
Wouldn't 12" centers be about 1,600 feet of tubing? It would be a little more for the manifolds but pretty close to a tube every foot. Certainly not 2,400 feet of tube in the floor.
Albert Einstein0 -
Z
there are in fact 3 lineal feet of tubing in two square feet . @ 0" - 12" - 24" . And due to the time of my post last night I reverted to my default 1 trip to the supply house calculation , I do apologise , after reading this now in my office after coffee and being wide awake I correct myself and say 12" center would require along the lines of 1,850 ft with leader lengths and 9" spacing would require about 2340 feet . You are correct .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
No worries...
I was checking my own sanity more than anything....."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Default in my mind
when I am out in a remote site I always order 3 lineal feet for every 2 square , 0" 12" 24" , 3 lineal feet for 2 sq . We save lots of trips this way and always have stuff in shop for those small jobs .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 960 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
