Rinnai r94ls Tankless and Propane?
Jimmytx
Jimmytx Member Posts: 1
Im about to score a Rinnai R94ls tankless and want to install it in a house out in the country that has propane.  Can this model run on propane?  It has been running on natural gas up to this point.
  • Eric_32
    Eric_32 Member Posts: 267
    You certainly....
    You certainly can run it off either LP or Nat. You will have to call Rinnai and order the correct conversion parts from them which will not be a problem.
    I have done it a couple times. It will also come with a new sticker stating it's now LP.
  • Tim McElwain
    Tim McElwain Member Posts: 4,657
    Better also contact the
    propane company to insure the tanks supplying propane are sized for the new perhaps additional load.
  • Slimpickins
    Slimpickins Member Posts: 359
    edited July 2014
    sure can
    You need a new gas manifold which includes the orifices and you need an LP air damper to make this happen. This work should only be done by a trained profession that knows how to use a manometer to adjust the gas valve pressure and make sure you have the right inlet pressure for the conversion. While you have the gas manifold off it will be a good time to clean the burners, heat exchanger and flame rod and electrode.
