Low flow air solar walls
G Twitchell
G Twitchell Member Posts: 10
I have not read any posts about these Conservall (brand name) type of solar collectors.
I installed these (4 - 4'X16') units about 7 years ago, they each have a 8" duct with a active damper and duct fan that is controlled by a demand stat and a micro processor at the top of each panel that says that the panel is warm/hot enough to come on.
I was concerned about tight house problem with my ICF construction and need make up fresh air and this works great.
I like this concept and it works for me.
George Twitchell
  • jumper
    jumper Member Posts: 2,526
    good old days
    Saw many installations in Canada on industrial buildings in nineteen seventies. Difference between comfy and chilly is only a few degrees.
    hot_rod Member Posts: 27,332
    SRCC is rating
    and certifying performance of air (transpired) collectors now. Some some actual performance and durability data is available. Looks like your brand is one of the listed.
    http://www.solar-rating.org/ratings/transpired_10001759_20140516.pdf
