True RMS
Servicewiz_3
Member Posts: 64
What is True RMS on my meter and will I need it for troubleshooting HVAC controls?
True RMS
should be a measure of the average voltage or current, over time (usually a very short time -- one cycle!), being measured -- as opposed to peak voltage, which would be the highest voltage. It's really only of concern with alternating current or rectified alternating current without capacitors, filters, chokes and sundry other bits used to smooth out the voltage or current. In alternating current, for example, the true average voltage or current is zero -- since half the time it's positive and half negative. Not a very useful result...
Do you need it to troubleshoot HVAC equipment? I doubt it, so long as you meter has some way to measure AC at all (and I've yet to see a multimeter which didn't).
It's actually not all that simple to build a circuit which will measure true RMS.Br. Jamie, osb
fairly necessary
if troubleshooting modern HVAC controls and equipment. I know the output from the triac relay on many solar controls cannot be read accurately with a non RMS meter. Worth the extra bucks I think.
A good RMS explanation here from Extech
http://www.youtube.com/watch?v=XUdRW0XgYQsBob "hot rod" Rohr
Fluke
Out of all the multimeters I have used, Fluke brought home the bacon on many different levels.
Harvey0 -
True enough, Hot Rod
and thank you. I was mired in the sine waves of the twentieth century!Br. Jamie, osb
Speaking of Extech
I just have to put in a plug for their 380942 mini clamp meter. I love my Fluke for higher power stuff, but the small jaw and high resolution of the Extech makes it perfect for a lot of troubleshooting tasks.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 115 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
- 49 Industry Classes
