Midco Radiant burner....results of first heating season
The Steam Whisperer (Formerly Boilerpro)
Member Posts: 834
My Burner Tech, Brad, installed a Modulating Midco LNB1000 on an old Pacific Steel boiler. While the combustion numbers on high fire were almost the same as the existing modern conventional burner, the fuel usage was dramatically different. Brad ran the numbers, correcting for degree days, and found over a 30% drop in fuel usage with the new burner. I suspect about 1/2 this drop is due to the modulation, but the other half is probably due to the better heat transfer of the radiant design. The installation was on a larger single zone, single pipe steam system.....no TRV's.
Looks like I'm going to start selling a lot of these
Not bad
for just changing the burner. What was in there before?All Steamed Up, Inc.
Consulting0 -
Wow, that was quick....
I think it was a Power FlameThere was an error rendering this rich post.
Modulating control
How was that Midco controlled?
It does look like the way of the future.--NBC0 -
Control system
I would still like to know how to control these burners.--NBC0 -
homemade modulating burner
http://news.discovery.com/tech/videos/visualizing-dubstep-with-a-rubens-tube-video-140613.htm0
- 109 Chimneys & Flues
- 976 Plumbing
- 387 Solar
- 17 Recall Announcements
