Name this part
Charlie from wmass
Member Posts: 4,322
Anyone know what this is
cell # 413-841-6726
cell # 413-841-6726
Here is a close up
Relief valve?Cost is what you spend , value is what you get.
cell # 413-841-6726
Relief Valve
I was going to guess a relief valve on the main water line. Just because it is cut-off at the line coming up and it appears to be a new poly line next to it?
Rob0 -
It was on
The return of a steam main.Cost is what you spend , value is what you get.
cell # 413-841-6726
I should have noticed
I should have noticed, it's not galvanized. Duh. What is / was its purpose?0 -
I don't know.
I cannot find it in my books. It is where the air vent is often put.Cost is what you spend , value is what you get.
cell # 413-841-6726
It's a very old main vent
which uses a carbon post as the expansion member.
You say it "was" on a return line?All Steamed Up, Inc.
Consulting0 -
Yes was
I redid the dry return and installed a Gorton 2. The steam comes around much faster now.
5Cost is what you spend , value is what you get.
cell # 413-841-6726
Well, that's the best reason
that it's no longer in service.
See if you can find a name on it. Maybe you'll get lucky and discover it's a Breckenridge!All Steamed Up, Inc.
Consulting0 -
Frank it is on it's way to China
It had not a single marking on it, be it patent number or manufacturer name or symbol. The homeowner was taking care of their own scrap. I was thinking of taking it as a souvenir but the idea of yet another piece of nonfunctioning iron on a shelf made me shutter, spring cleaning mode right now.Cost is what you spend , value is what you get.
cell # 413-841-6726
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
