hydronic or forced air heat
pappa
Member Posts: 2
HI first time here I built a 32x40 residential pole shed with 10/12 pitch ,vinyl siding and a steel roof a living area above [man cave]. so I will also need a hot water heater and air cond.
I haven't done concrete yet would you suggest hydronic infloor or forced air house furnace 96% efficient . I have ten foot ceilings if I do infloor how do I get air cond for the upper level. which will be the cheapest to run on nat gas. also by code I believe if I went forced air I would need two furnaces. I live in minnnesota
Hydronic
Have a room by room heat loss done . Use the water heater as your source for space heating also and put a properly sized ductless split for ac . More details would be good like is the upper level open to below ? What are the R values of the walls , roof , how many , what type , what size windows and doors . Can you draw a floor plan showing these things for us ?You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
windows
it will have a separate entrance for up stairs I small window 10"x24" on the main level and upstairs 4 - 18x 30' windows . no insulation right now0 -
Rich
Is right, radiant floor, ductless ac .0
- 87K THE MAIN WALL
- 114 Chimneys & Flues
- 106 Geothermal
- 982 Plumbing
- 388 Solar
