Head Pressure Controls
Techman
Member Posts: 2,143
On AC&R equipment, that has a factory installed "head pressure controlling device(s)",what is the CondensingTemp, that the factory pre-set these devices for?Or the pressurers that these devices operate at is just as good!
Depends on the refer
It would depend on the refrigerant. The head pressure control for 410A would be set much higher than it would for 22 or 407, etc...
And, if it is being used for low ambient operation, then those settings would be different still.
Did you have a specific application that you were thinking about?0 -
HPC's
Hi Chris, this is more about trying to get a couple of brother wallies to see/get a point about" HeadPressure", about CT-CondensingTemperature( which does not change) about CondensingPressurers( which does change). I ask questions so that others don't have to! Or not sure how to! I'll ask!!!!!!!!!!!!!!!0 -
HPC
That is great Terry. Plenty rolling around in my head, if you can figure out what question to ask in order to pry it out.0 -
This is fun.
Pop Quiz.
HPC's need to maintain approximately 90° to 100° condenser temperature for a couple reasons. The temperature/pressure needs to be high enough to provide effective heat rejection in the summertime and maintain a full liquid line. The CP needs to remain fixed (not allowed to go below a certain level) in order for the metering device to function properly and also to prevent the compressor from short cycling on the low pressure cut/out switch. (normal system)
Harvey0 -
HPC's
OK ,Mr.meplumber, here goes,hmmmmmmmmmmmmmmm!!!!!! I see a bank, I see lots of money,I see lots of cameras,and I see (horizontal) pin stripe suits. So I'm going to say "no" not this way! LOL .0
- 87.8K THE MAIN WALL
- 131 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
