Smallest wall mount mini split available???
Danscrew
Member Posts: 130
Who makes the smallest mini split ? Wall mount that is All I see is 9000 BTU ?
7500 BTU/hr
is available from Daikin in some of their lines.0 -
7k
Fujitsu also has a 7k. But remember that they modulate their output, so in low fan speed you are only putting out something like 2300 btu/hr.0 -
Small mini splits
I only see lower BTU units in multi zone systems. I need a single zone cooling only for a 12 x 12 bed room. So if I had a 9000 running at minimum that would be 3800 that would still be too much it might short cycle and not dehumidify the space ? thanks Dan0 -
Small is beautiful
we could really use some tiny options in the market (so similar to the situation with gas-fired boilers.)0
- 87.1K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 998 Plumbing
- 391 Solar
- 55 Water Quality
