Smallest wall mount mini split available???
Who makes the smallest mini split ? Wall mount that is    All I see is 9000 BTU ?
  • SWEI
    SWEI Member Posts: 7,342
    edited May 2014
    7500 BTU/hr
    is available from Daikin in some of their lines.
  • meplumber
    meplumber Member Posts: 673
    7k
    Fujitsu also has a 7k.  But remember that they modulate their output, so in low fan speed you are only putting out something like 2300 btu/hr.
  • Danscrew
    Danscrew Member Posts: 130
    Small mini splits
    I only see lower BTU units in multi zone systems. I need a single zone cooling only for a 12 x 12 bed room.  So if I had a 9000 running at minimum that would be 3800 that would still be too much it might short cycle and not dehumidify the space ?  thanks Dan
  • SWEI
    Small is beautiful
    we could really use some tiny options in the market (so similar to the situation with gas-fired boilers.)
