Converting 277/1/60v heat pump to run on 230/1/60v ... ??
Geothermal_1
Geothermal_1 Member Posts: 4
I have an opportunity to get a second heat pump for my geothermal at a good price, but it is 277/1/60 (265v). My house is single phase 230v.
How difficult and would it be worth it to convert the unit to my household service?
Would a buck-boost transformer be a reasonable solution?
Thanks.
  • Geothermal_1
    Should I repost this in a different section?
  • SWEI
    SWEI Member Posts: 7,348
    Assuming the unit is sized correctly
    and all of that, and that the price is good enough you don't mind having to explain to the service tech every time he arrives, you could install an autoformer to power it from 240V.   Unless there is sufficient space in the high voltage section of the cabinet, you will need to install an external enclosure for the autoformer (some come with one.)
  • Geothermal_1
    Any Disadvantages?
    other than having to add auto transformer.
  • SWEI
    Possible code issue
    if the job is going to be inspected, assuming it is a residence.  Otherwise no real issues that I can see.
  • Geothermal_1
    Thank you for your time
    I will have to decide
