Flue liner question
Soilidventur
Soilidventur Member Posts: 7
i'm a homeowner new to this board. I've got a steam heat system with a 9yo Weil MClain Gold Series 3 114k BTU boiler currently on #2 fuel oil. My chimney has a cracked flue that needs to be relined (per the chimney sweep). I may convert the burner to gas and my question is can I install a liner that handles exhaust from either the oil burner or a new gas burner? Does A1 20-4C stainless steel handle both? Is there a better or more cost effective lining material?
  • Tim McElwain
    Tim McElwain Member Posts: 4,655
    A stainless steel
    liner is good for both gas and oil. What are your plans as far as a conversion burner? What is your location?
  • Soilidventur
    Flue liner/gas coversion
    Thanks for your response. I'm in Boston, looking at Carlin EZ Gas Pro or a Riello 40 GSD Series. Some threads mention problems with the gas conversion (warranty void on the boiler, cheap components and more gun maintenance, loud noise level, different size chambers) so I'm still investigating.
    Last season we burned 471 gal of oil, the equivalent therms of gas is 625-635 so the savings is significant.
    Any special considerations for a steam system that I should keep in mind?
  • BobC
    BobC Member Posts: 5,523
    edited May 2014
    Somewhat noisy
    I'm south of Boston and had a Smith G8 (no longer being made) installed in 2012 with the EZ-Gas instead of an oil burner. My boiler is the smallest in that line and does have a rumble to it. I was able to down fire it and tame the rumble somewhat; the boiler is rated for a lot more steam than my system needs.
    I have used it since October of 2012 without any issues.
    Bob
    3PSI gauge
