Is R-410a a blend
steve_25
Member Posts: 36
Is R-410a ablend? Do you have to charge a air conditioner that uses R-410a only as a liquid, or can you also charge as a vapor?
Yes
It is a blend and must be charged as a liquid.Steve Minnich0 -
R-410A
Yes, R-410A is a blend, but a unique blend.
Typically, if a system that operates with a refrigerant blend develops a leak, the remaining refrigerant needs to be recovered and new refrigerant added to the system. In the case of R-410A, systems can be "topped off" due to the low temperature glide (0.3 degrees) of the refrigerant.
As a blend, R-410A is to leave the tank as a liquid.There was an error rendering this rich post.
- 123 Chimneys & Flues
