Is R-410a a blend
Is R-410a  ablend?  Do you have to charge a air conditioner that uses R-410a only as a liquid, or can you also charge as a vapor?
  • Steve Minnich
    Steve Minnich Member Posts: 2,895
    Yes
    It is a blend and must be charged as a liquid.
    Steve Minnich
  • Eugene_Silberstein
    Eugene_Silberstein Member Posts: 349
    R-410A
    Yes, R-410A is a blend, but a unique blend.
    Typically, if a system that operates with a refrigerant blend develops a leak, the remaining refrigerant needs to be recovered and new refrigerant added to the system. In the case of R-410A, systems can be "topped off" due to the low temperature glide (0.3 degrees) of the refrigerant.
    As a blend, R-410A is to leave the tank as a liquid.
