AntiFreeze leaks.
Techman
Member Posts: 2,143
What can be used to clean up antifreeze& the "residue" from a leaking tridicator that collected on top of the boiler? Then how about that bluish/greenish stuff on the brass fittings on some manifolds? Thanks!
water
and a small wire brush or old fitting brush.
But it may come back! It's a tough fluid to keep inside.Bob "hot rod" Rohr
chances are
the paint will wash off with the residue. Warm soapy water, and don't rub too hard. Check the PH also0
