AntiFreeze leaks.
Techman
Techman Member Posts: 2,143
What can be used to clean up antifreeze& the "residue" from a leaking tridicator that collected on top of the boiler? Then how about that bluish/greenish stuff on the brass fittings on some  manifolds? Thanks!
    hot_rod Member Posts: 26,597
    water
    and a small wire brush or old fitting brush.
    But it may come back! It's a tough fluid to keep inside.
  • billtwocase
    billtwocase Member Posts: 2,384
    chances are
    the paint will wash off with the residue. Warm soapy water, and don't rub too hard. Check the PH also
