Triangle Tube Prestige Solo
JonnyA
Member Posts: 1
in Gas Heating
A Triangle Tube Prestige Solo 175 was recommended. Can anyone tell me how reliable this unit is? Was also considering Weil-Mclain or a Buderus. I am looking for a high efficiency reliable gas boiler.
Triangle Tube
It's the only brand we use right now. Huge thumbs up!0 -
Solo
Great boiler, excellent support.
Be sure to get an installer that understands Mod/con boilers.
A 175 is a larger boiler. How was the sizing determined?
Albert Einstein0 -
I use a solo 175 in my own house
Its is a large boiler, oversized for my 4000 sq ft.. Make sure you perform a heatloss and install what you need, larger will cause problems..0 -
have a 110
In my own house. It is THE boiler to have all things considered IMO. be sure a structure heat loss is done and the installer follows the installation instructions to the letter.0
