Triangle Tube Prestige Solo
JonnyA
JonnyA Member Posts: 1
A Triangle Tube Prestige Solo 175 was recommended. Can anyone tell me how reliable this unit is? Was also considering Weil-Mclain or a Buderus. I am looking for a high efficiency reliable gas boiler.
  • JStar
    JStar Member Posts: 2,752
    Triangle Tube
    It's the only brand we use right now. Huge thumbs up!
  • Zman
    Zman Member Posts: 7,609
    Solo
    Great boiler, excellent support.
    Be sure to get an installer that understands Mod/con boilers.
    A 175 is a larger boiler. How was the sizing determined?
    Carl
    Albert Einstein
  • heatpro02920
    heatpro02920 Member Posts: 991
    I use a solo 175 in my own house
    Its is a large boiler, oversized for my 4000 sq ft.. Make sure you perform a heatloss and install what you need, larger will cause problems..
  • Bob Bona_4
    have a 110
    In my own house. It is THE boiler to have all things considered IMO. be sure a structure heat loss is done and the installer follows the installation instructions to the letter.
