Looking for residential installer in Denver, Colorado
thermos
Member Posts: 2
I'm looking for an experienced HVAC installer in the Denver, Colorado area. I'm looking to replace a gas boiler serving baseboard radiators with a Daikin Altherma or similar air-to-water heat pump product. Ideally the installer would be familiar with Daikin products and controls.
Thanks.
Thanks.
hvac contractor
Pasterkamp Heating or AMS mechanicalThere was an error rendering this rich post.
Start with the Daikin rep...
Shamrock Sales, three zero three-399-9181
Are you absolutely sure it will work? There are limitations on the temperature output of these ASHP systems that may not be compatible with your system design. Baseboard is typically designed around a 180 degree F average temperature.
ME0 -
Limits
I agree with Mark the highest I want to push one would be 125 degree max.Anything over that in you are going to reduce the life of the equipment very quickly.0 -
Thanks. I appreciate the suggestions. The installer suggested by Shamrock Sales never got back to me with a quote, but I have a couple of other leads and I'll try Paskerkamp and AMS.
The baseboard are Crane cast iron radiators, which I have calculated to provide ~200-230 Btu/LF at 120ºF supply temp. This should meet the needs of my low-load house (yes, I have a Manual J heat load estimate) for all but the coldest days. If necessary, I will install some panel radiators or just use a electric resistance heater on those days.0
