Rehau
Lynne
Member Posts: 50
Anyone use Rehau radiant pex tubing? What type of fittings and is there a special tool?
Rehau
Rehau has their own proprietary fittings but I also have a bulletin from them approving the use of crimp rings with their tubing. I'm not certain as to whether the information in that bulletin has changed.Steve Minnich0 -
Rehau
Thanks, do you have a copy of that bulletin?0 -
PEX-A
is compatible with all PEX connector systems.
PEX-B is not compatible with expansion systems (F1960, F2080)
For reference:- ASTM F876 Standard Specification for Crosslinked Polyethylene (PEX) Tubing
- ASTM F877 Standard Specification for Crosslinked Polyethylene (PEX) Plastic
Hot- and Cold-Water Distribution Systems - ASTM F1281 Standard Specification for Crosslinked Polyethylene/Aluminum/Crosslinked
Polyethylene (PEX-AL-PEX) Pressure Pipe - ASTM F1807 Standard Specification for Metal Insert Fittings Utilizing a Copper Crimp Ring
for SDR9 Cross-linked Polyethylene (PEX) Tubing - ASTM F1960 Standard Specification for Cold Expansion Fittings with PEX Reinforcing
Rings for Use with Cross-linked Polyethylene (PEX) Tubing - ASTM F2023 Standard Test Method for Evaluating the Oxidative Resistance of
Cross-linked Polyethylene (PEX) Tubing and Systems to Hot Chlorinated Water. - ASTM F2080 Standard Specification for Cold-Expansion Fittings with Metal Compression-Sleeves
for Cross-linked Polyethylene (PEX) Pipe - ASTM F2098 Standard Specification for Stainless Steel Clamps for Securing
SDR9 Cross-linked Polyethylene (PEX) Tubing to Metal Insert Fitting
- 87.1K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 998 Plumbing
- 391 Solar
- 55 Water Quality
