Herman Nelson, Trane unit heater sizing
Subtle Steam
Member Posts: 3
I am trying to locate BTU capacity, EDR, and/ or pounds condensate per hour on the
following steam fan forced unit heaters: Herman Nelson model TSU 1031 and a
round Trane model 100P. Both are at least 40-50 years old. The boiler pressure is about 5 psi. The Trane unit is round and the herman nelson is rectangular. Thank you in advance!
Good place to start
is here:
http://www.heatinghelp.com/article/172/Unit-Heaters/1403/Trane-unit-heaters
If you can't find anything else, go by the capacity of the steam pipe feeding the heater.All Steamed Up, Inc.
Consulting0
