Relay Wiring
zeroarctic
Member Posts: 1
I recently had a radiant zone added to my existing baseboard system. The manifold came with a i-Link SP-81. The existing aquastat/controller is a Honeywell 8148a with Taco Zone Sentry valves. . The tech plans to wire the tt from the i-link to the tt on the 8148a . Is this proper as the tt from the zone valves is already connected?
Is the radiant zone
on one of the Taco Zone Valves? Typically the zone valves are powered by the sensing control and the end switch on the zone valve brings on the relay which fires the burner and brings on the circulator. I am not completely aware of what the i -link SP-81 does?0
- 50 Industry Classes
