The Alpha, what is auto adapt
PLUMMER
Member Posts: 42
Can anyone tell me exactly how auto adapt works. What is it sensing to make its changes. I've looked thru a lot of material to find what exactly it's reading from seminar to their website.
The other run speed options are explained well enough for customers to understand. Thanks.....
Pressure
Runs with pressure, the only way I can explain is ...... If you have zone valves and when one shuts off it will creat a bang when the boiler shuts off, this wil adjust the waters pressure inside the system.0 -
Alpha
This post covered this pretty well
http://www.heatinghelp.com/forum-thread/149587/How-exactly-does"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Many thanks
After reading those threads, it makes a lot more sense. And explains the differences I see. Since TRV's aren't that common here, the fixed pressure has less call backs. These threads explained far more than my reps or manuals have on a definitive answer. Differential bypasses help0
