Please help aquastat
Does anybody know of a Honeywell L8148a is the same as a
L8148J
  • Big Ed_4
    Big Ed_4 Member Posts: 3,529
    difference
    Kinda the same in most common systems ... The J can also be used on a 24V and millivolt gas valve and a low limit can also be added ....
  • Tim McElwain
    Tim McElwain Member Posts: 4,660
    No it is not the
    L8148A is a 120 volt burner circuit. The L8148J is a universal replacement relay for 24 volts of millivolts(Powerpile Self Generating). You have to replace an "A" with an "A".
