The Alpha, what is auto adapt
PLUMMER
PLUMMER Member Posts: 42
Can anyone tell me exactly how auto adapt works. What is it sensing to make its changes. I've looked thru a lot of material to find what exactly it's reading from seminar to their website.
The other run speed options are explained well enough for customers to understand. Thanks.....
  • Snowmelt
    Snowmelt Member Posts: 1,428
    Pressure
    Runs with pressure, the only way I can explain is ...... If you have zone valves and when one shuts off it will creat a bang when the boiler shuts off, this wil adjust the waters pressure inside the system.
  • Zman
    Zman Member Posts: 7,611
    Albert Einstein
  • PLUMMER
    Many thanks
    After reading those threads, it makes a lot more sense. And explains the differences I see. Since TRV's aren't that common here, the fixed pressure has less call backs. These threads explained far more than my reps or manuals have on a definitive answer. Differential bypasses help
