Please help aquastat
Dac7660
Member Posts: 1
Does anybody know of a Honeywell L8148a is the same as a
L8148J
L8148J
difference
Kinda the same in most common systems ... The J can also be used on a 24V and millivolt gas valve and a low limit can also be added ....There was an error rendering this rich post.
No it is not the
L8148A is a 120 volt burner circuit. The L8148J is a universal replacement relay for 24 volts of millivolts(Powerpile Self Generating). You have to replace an "A" with an "A".0
- 50 Industry Classes
