Sizing old cast iron water radiators that froze
bob eck
Member Posts: 930
I was given the following info from a heating contractor asking me to size replacement cast iron water radiators from this info.
7'x32" wall hung cast iron rad
9'x32" wall hung
25"x17" 4 pass
8'x32" wall hung
24"x32"x10" 3 pass
32"x42"x10" 3 pass
32"x32"x10 3 pass
32x32x10 3 pass
28"x25"c7" 6 pass
32"x12"x10" 3 pass
32"x18"x10" 3 pass
32"x30"x10" 3 pass
48"x24"x7" 6pass
Can anyone size from this info
I was always told you need the following info
Height
Number of sections
Number of tubes or columns.
Water or steam system.
Am I correct?
Thanks
9'x32" wall hung
25"x17" 4 pass
8'x32" wall hung
24"x32"x10" 3 pass
32"x42"x10" 3 pass
32"x32"x10 3 pass
32x32x10 3 pass
28"x25"c7" 6 pass
32"x12"x10" 3 pass
32"x18"x10" 3 pass
32"x30"x10" 3 pass
48"x24"x7" 6pass
Height
Number of sections
Am I correct?
Thanks
Radiation tables
See the attached tables. Then multiply the square footage x 150 for 170* average water temp to get the btu output.Bob Boan
CI radiators
I have Dan's EDR book but he did not tell me how many sections so how am I supposed to figure it out?0 -
How...
Could anyone figure it without knowing how many sections? He needs to supply you that info.Bob Boan
Room by room heat loss?
Would that be worth the trouble?--NBC0 -
CI radiators
That is what I asked him for the number of sections for each radiator. He told me another wholesaler with the same info figured out the BTU for each radiator. I guess that other wholesaler is better than me and my technical people. Maybe if that wholesaler sold the old radiators they would never have frozen and broke in the first place and they would have been shipped with special water.0 -
Heatloss
I'm only a homeowner, but my guess is it was hot water and not steam because they froze.
That said, I agree with NBC, now is the time to do a heatloss and size the radiation accordingly. No one knows is the originals were sized right so why assume.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Sizing radiators:
You are right. But they didn't give you the proper measurements.
Take for example, one that is listed as "24X32X10 3 pass".
There isn't a 24" high radiator but there is a 25" high and a 32" high radiator in the table. Modern radiators aren't given a width measure so the "10" may be true, but it probably is a "3-pass"" or 3 column radiator. So, a radiator that is 32" high and is a 3 tube/column radiator, according to the tables is 3 Sq. Ft per section. Radiators are sold by the Sq. Ft. So, if the radiator is a 10 section, it has 30 Sq, Ft of radiation. Tell the supply house that they need to call one of their old retired guys who know something. Or, get away from the coffee pot, quit texting someone, and call someplace that they will be buying radiators from.
Better yet, if you buy from the wholesaler I used, they would build them or repair then right in one of their stores. Test them and deliver them.
And they know what they are talking about. If those radiators are "modern radiators", they can probably be repaired. Usually, only the end sections break.
I hope that it is comprehensible.0
- 110 Chimneys & Flues
- 978 Plumbing
- 387 Solar
- 17 Recall Announcements
