Hot Rod
Robert_H
Member Posts: 251
I sent you a message via the "contact use" feature of the forum recently. I just want to make sure it got through to you.
thanks
Robert
thanks
Robert
I did and responded
maybe check your junk file? or send me an e-mail, i sent it Feb. 28 at 2:32.22 PM
I checked, not in junk or trash
I found an email address for you and forwarded the original to you.
Thanks
Robert0 -
FWIW:
I've found in responding, you have to respond to the questioners E-Mail account and not reply to where the E-Mail came from, heatinghelp.com. If you do, it seems to go to some large trashcan in the back insides of the server.
Click on the E-Mail address in the message.
At least that's how it worked in the old system. Its probably the same here now.0
- 167 Indoor-Air Quality
