Hot Rod
Robert_H
Member Posts: 141
I sent you a message via the "contact use" feature of the forum recently. I just want to make sure it got through to you.
thanks
Robert
thanks
Robert
I did and responded
maybe check your junk file? or send me an e-mail, i sent it Feb. 28 at 2:32.22 PMBob "hot rod" Rohr
Living the hydronic dream0 -
I checked, not in junk or trash
I found an email address for you and forwarded the original to you.
Robert0 -
FWIW:
I've found in responding, you have to respond to the questioners E-Mail account and not reply to where the E-Mail came from, heatinghelp.com. If you do, it seems to go to some large trashcan in the back insides of the server.
Click on the E-Mail address in the message.
At least that's how it worked in the old system. Its probably the same here now.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
