Pre-Made Radiant Manifolds
Zad
Member Posts: 19
I am a DIY'r with one radiant system that has worked perfectly for the last 5 years under my belt. I am just planning my second system that I will install in our home and am curious about the value in buying a pre-made manifold. In the previous system I built I just used the basic copper manifold with 3/4" inlet and 1" trunk and tied my 1/2" pex into it. I see online that I can buy pre-made manifolds (5 circuit) out of ss for as little as $160 from pexsupply and pexuniverse and from companies like Radiantec in copper for $370. Is there an advantage to these pre made units other than the obvious of some time saving? In our new system I will have one zone with 5 circuits, two zones with two circuits and one zone with one circuit. Each circuit will be 200-300 feet in length using 1/2" pex tubing. Any input would be appreciated.
Thanks.
Thanks.
There are advantages
Not all manifolds are made equal, but a decent one will combine some type of on-manifold flow balancing with reasonably accurate flow meters, loop isolation valves, means for bleeding air... On better ones, you can expect that all these features will be somewhat easier to use/more predictable and accurate, and that any replacements that fit the manifold will still be available years down the road when you need them.0 -
Manifolds
Before you buy at pex supply I would like for you to shop at a larval supply house, they will sell the same thing, plus you will be helping you local plumbing supply house.0 -
Larval???
I assume you ment local?
ETA: What happened to my smiley? I was joshingThere was an error rendering this rich post.
Local
Yes local would be the word.0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
