Radiators
John Fernandez_2
Member Posts: 40
I am replacing some old cast iron radiators with some new ones. The old radiators were piped with the supply and return piping at the bottom of the radiators, this was an old gravity type hot water system. I am also replacing the boiler, the new system will have a circulator pump. My question is: what is the best piping arrangement on the radiators as far as supply and return piping? Thank you.
Radiators
Where are you located? If you are dead-set on getting rid of the old radiators, I will take them from you. Do not send them to a junkyard, please!0 -
Radiators
I am on Colorado......the radiators I am replacing we're frost damaged.0 -
Piping hot...
In the bottom, and out the top opposite corner from the inlet.
Low head/low flow pumps are a must,otherwise the water whips through the radiators so fast it doesn't have a chance to transfer the heat to the walls of the radiator.
ME0 -
Radiators
Thanks Mark!0
- 87K THE MAIN WALL
- 111 Chimneys & Flues
- 106 Geothermal
- 979 Plumbing
- 387 Solar
