Steam radiators
Jason_13
Jason_13 Member Posts: 305
I am looking for steam radiation that would take daily room washing. The application
Cation is a food processing room that completely gets washed down everyday so rusting is not an option.
  • Rust-proof rads
    Radiators can be made of straight copper piping, if the slopes are correct. It would be best to pipe the room as a two-pipe setup, with a drop down to below the waterline for a wet return.
    Alternatively, the pipe radiators could be fed on a hot water loop from the boiler.
    How far away is the boiler?
    Is the rest of the system one pipe or two?
    What is the heating load of the room?
    Pictures of the boiler, and radiators would be helpful.--NBC
  • JohnNY
    JohnNY Member Posts: 3,341
    rust resistant
    Before I advised making steam radiators out of copper tubing, I'd be more inclined to suggest cast iron or steel radiators that are either painted/powder coated in the field or factory.
    Here's a decent start:
    http://steamradiators.com/orderingpages/charlestonpro.html
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
