Steam radiators
Jason_13
Member Posts: 305
I am looking for steam radiation that would take daily room washing. The application
Cation is a food processing room that completely gets washed down everyday so rusting is not an option.
Rust-proof rads
Radiators can be made of straight copper piping, if the slopes are correct. It would be best to pipe the room as a two-pipe setup, with a drop down to below the waterline for a wet return.
Alternatively, the pipe radiators could be fed on a hot water loop from the boiler.
How far away is the boiler?
Is the rest of the system one pipe or two?
What is the heating load of the room?
Pictures of the boiler, and radiators would be helpful.--NBC0 -
rust resistant
Before I advised making steam radiators out of copper tubing, I'd be more inclined to suggest cast iron or steel radiators that are either painted/powder coated in the field or factory.
Here's a decent start:
http://steamradiators.com/orderingpages/charlestonpro.htmlContact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0
- 114 Geothermal
