can hot water radiator supply lines be dropped 6" for ~5 feet?
RunnerSt
Member Posts: 1
I am moving a radiator in a hot water system about 10 feet. The bathroom's floor joists are 2X6s @16" where the radiator is now and about halfway to where I want to end up they become 2X12s @24". The ceiling below this room is dropped about a foot, so the easiest approach is to run the existing supply and return lines to the 2x12's, drop them 6" and come up in the new location. Alternatively, I could drill through the 2x12's to maintain the height of the lines. If I go the easy route, I cannot really drain the system completely and I could trap air, but since the system is being pumped, does it matter which I do? Thanks
Doesn't matter. Just do it.
Some will argue you'll be creating an air trap, which you could solve easily by using tees and air vents at the downstream high point of your offset behind an access panel but I'll bet you'll have no problem doing what you describe.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
Jumpers
We do them all the time. I'm against remote air vents though, as I've seen plenty actually allow air in to the system. Just do a thorough job of purging and make sure you have an effective air eliminator at the boiler.0
