Bonnet capacity
charliechicago
Member Posts: 168
Hello to all
What does bonnet capacity mean.
I have a friend that wants to replace his forced hot air system that says input 100000 btu bonnet capacity 80000 btu
I know it differs from afue but is this an 80% furnace?
Thanks Michael
Thanks Michael
Output
Bonnet is outputTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Chimney liner
So if I replace it with an 80% I don't need a liner?0 -
Not 80%
That's not an 80% furnace, it's probably 65% at best. Any thing that would have "bonnet capacity" stamped on it is probably at leas 35 years old, maybe much more.
A new 80% furnace must have a liner installed with it to prevent flue gas condensation. By the time you pay for that, you could have gotten a 95% one and been better off in most cases.
Also, a heat loss calculation needs to be done as the old furnace is probably way over-sized for the house and a higher efficiency furnace would have more output.Bob Boan
Iron man
Thank u for the response. You are right that it's an old furnace as you can see from the picture. I had been told exactly what u said but I wanted confirmation. Also that's a great idea about a condensing unit. But I'm still wondering what exactly does bonnet capacity actually mean. Thanks mike0
- 109 Chimneys & Flues
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
