Aquastat
Kris243
Member Posts: 1
Hello, new to this site. I was wondering if anyone would happen to know of any available Aquastats with a 120 VAC output. The Aquastat should be able to supply power to a recirculation pump. Thanks!
Aquastat
There are many types of aquastat that will work. Here is a common one that will strap on the pipe. http://www.pexsupply.com/Honeywell-L6006C1018-High-or-Low-Limit-Circulator-Strap-On-Aquastat-65-200F-range-5-30F-Adj-Differential-1738000-p
Keep in mind that an aquastat is just a switch. It does not provide power. As long as it is rated for the voltage and amperage you are using, it will work.
Albert Einstein0
- 120 Geothermal
