Kickstart THIS!
Eastman
Eastman Member Posts: 1,002
I'm curious to hear what other ideas people would consider supporting via crowd funding. Smart vents that ensure balance? Variable EDR radiator valves? ???
What's missing from modern steam?
  • Eastman
    The alternatives
    are quite expensive?
  • Joe V_2
    Joe V_2 Member Posts: 233
    what's missing from modern steam?
    Knowledge, of course! that's why we come here.
    actually, I believe steam has plateued because the market is shrinking. A 90%+ efficient boiler maybe?
  • ChrisJ
    ChrisJ Member Posts: 17,390
    Fix that
    How can you make the market grow?
    How can you make a steam system that will compete with other cheaper systems?
    You would think a system with almost no moving parts, no pumps, no fans, could be made to be cheaper then forced hot air, some how.
    I'm all for an outdoor reset for systems like mine.
  • JStar
    JStar Member Posts: 2,752
    ODR
    Mark, I think we have a great candidate in ChrisJ for a launch prototype! He lives a few towns over from me, so callbacks won't be brutal.
  • ChrisJ
    Absolutely
    I'd be glad to be a test subject if the opportunity ever presents it self.
  • I'm ready
    Also, could your control system be adapted to a hot water boiler, for a wider audience?--NBC
    Steamhead Member Posts: 18,502
    Consulting
  • Joe V_2
    edited February 2014
    well that microsteam system certainly sounds intriguing
    I dont know how I missed that thread.
  • gerry gill
    gerry gill Member Posts: 3,084
    a code approved
    millivolt gas valve would be nice..steam boilers could be rated at higher efficiency i would think if they also used no electricity.
    gwgillplumbingandheating.com
  • gerry gill
    The return of the
    Hoffman #10 main vent would also be nice..the only thing venting faster than that was an open 1/2'' pipe.
  • Eastman
    3/4 inch mains
    I'm looking back through the SelectTemp brochures. The technology seems so relevant to today. Is there a design/install manual out there somewhere?
  • Gordo
    Gordo Member Posts: 857
    Things I'd Like to See With Steam
    1) Hi-Lo firing in all size models.
    2) Accurate low pressure transducers in place of pressuretrols or even Vaporstats with direct digital read-outs of actual system pressures.
    3) A high temperature sensor in the flue gas stream to shut down boiler to prevent dry-firing in the event of LWCO failure.
    4) Sightglasses with ALL brass components and proper blow-down valves.
    5) A main vent with twice the venting as a Gorton #2.
    6) An affordable single pipe steam TRV.
    7) 3 small tube cast iron radiators made in the USA.
    8) Affordable firing cycle/outdoor reset t-stat (as others have said above)
    9) Add an O2 sensor in the flue gas stream, combine with the temperature sensor above add a processor (from an I-phone app) and get real time combustion efficiency...
    *sigh*
    Dream on, I guess.
