reducing bushings
Flip
Member Posts: 40
Any one know where I might get my hands on eccentric reducing threaded bushings? Need a couple for the outlet on my radiators.
When reducing
from large to small on a horizontal condensate return line, you want to use an eccentric reducing coupling to avoid trapping a pocket of condensate upstream. My sources tell me these are readily available. In the Chicago area I use Columbia Pipe & Supply and Porter Pipe.
Now a reducer bushing, that's another matter. Couldn't find any source. Depending on the pipe sizes and the amount of offset needed, anybody with a decent lathe could make one from a common pipe plug. Check with your near-by machine shop, or friendly home shop machinist. Just a question of setting up the offset, then drilling and tapping for the smaller size.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0 -
reducing bushings
thanks for the come back. have a two flat with 20 rads all have this bushing at the rad outlet. believe you must be right about having them machined, cannot find this fitting anywhere. thanks again0 -
If you'd like,
I can tell you how to contact a home shop guy that offered to make me a double tapped tank bushing. I'm sure he could make these eccentric bushings for you.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
concentric bushings
what size do you need .I may have some 1 1/4 x 1/2 at my shop I will look if that is the size you need.0
- 120 Geothermal
