reducing bushings
Flip
Flip Member Posts: 40
Any one know where I might get my hands on eccentric reducing threaded bushings? Need a couple for the outlet on my radiators.
  • Pumpguy
    Pumpguy Member Posts: 801
    When reducing
    from large to small on a horizontal condensate return line, you want to use an eccentric reducing coupling to avoid trapping a pocket of condensate upstream.  My sources tell me these are readily available.  In the Chicago area I use Columbia Pipe & Supply and Porter Pipe.
    Now a reducer bushing, that's another matter.  Couldn't find any source.  Depending on the pipe sizes and the amount of offset needed, anybody with a decent lathe could make one from a common pipe plug.  Check with your near-by machine shop, or friendly home shop machinist.  Just a question of setting up the offset, then drilling and tapping for the smaller size.
  • Flip
    reducing bushings
    thanks for the come back. have a two flat with 20 rads all have this bushing at the rad outlet. believe you must be right about having them machined, cannot find this fitting anywhere. thanks again
  • Pumpguy
    If you'd like,
    I can tell you how to contact a home shop guy that offered to make me a double tapped tank bushing.  I'm sure he could make these eccentric bushings for you.
  • kevin_58
    kevin_58 Member Posts: 61
    concentric bushings
    what size do you need .I may  have some 1 1/4 x 1/2 at my shop I will look if that is the size you need.
